Polygons
Sketch and edit a parallelogram or a regular polygon.
Sketch a Parallelogram
Sketch a parallelogram.
On the Sketch ribbon, select the
Parallelogram tool.
- Select a face or plane as the sketch plane.
- Click three times on the sketch plane to place three corners of the parallelogram.
Edit a Parallelogram
Reposition, resize, or apply a sketch constraint.
Sketch a Regular Polygon
Sketch a regular polygon.
Edit a Regular Polygon
