/INIBRI/EPSP
Block Format Keyword Describes the initial state for a brick.
/INIBRI/EPSP/unit_ID
brick_ID   value
unit_ID Unit Identifier
(Integer, maximum 10 digits)
brick_ID Element identifier
(Integer)
value Date value
(Real)
  1. /MAT/LAW38 (VISC_TAB) is not compatible with /INIBRI/EPSP.
  2. The initial state for brick may be defined by more than one block.
