DI Card
This card can be used to define the frequency dependent or independent material characteristics of a dielectric medium, metallic medium or an impedance sheet.
In the Home tab, in the Define group, click
        the
  Media icon. From
        the drop-down list select the
 Dielectric (DI) icon.
Figure 1. The DI - Set medium properties dialog.
Parameters:
- Medium label
 - Label of the material to be defined.
 - Define dielectric medium
 - Define a dielectric medium by specifying a wideband model or loading points from a file and using linear interpolation. The following wideband models are available: Constant (Frequency independent), Debye relaxation, Cole-Cole, Havriliak-Negami and Djordjevic-Sarkar (Wideband Debye).
 - Define metallic medium
 - Define a metallic medium by specifying the frequency independent parameters or loading points from a file.
 - Define impedance sheet
 - Define an impedance sheet by specifying the frequency independent real/imaginary part of the impedance or loading points from a file.
 - Define anisotropic medium
 - Define an anisotropic medium by means of specifying either the Full tensor, Diagonal tensor, Complex tensor or Polder tensor (ferrites).
 - Define characterised surface medium
 - Define a characterised surface medium by loading the transmission and reflection coefficients from a .tr file.(as specified in the DA card)
 - Source
 - Define the medium by means of a wideband model or loading points from a file.
