SB Card
This card specifies an external magnetostatic bias field applied to a 3D anisotropic medium (ferrite).
In the Home tab, in the Define group, click
the Media icon. From
the drop-down list select the
Magnetic bias (SB) icon.
![](../../../../../../images/feko/user_guide/editfeko_cards/dialog_sb.png)
Figure 1. The SB - Specify a magnetostatic bias field to be applied to an anisotropic medium (3D) dialog.
Parameters:
- Magnetostatic bias field name
- The name of the magnetostatic bias field name to be defined.
- Label of the anisotropic medium
- Label of the anisotropic medium (ferrite) to which the magnetostatic bias field is applied.
- DC bias field (Oersted)
- The magnitude of the DB bias field in Oersted.
- Field direction
- The direction the magnetostatic bias field is applied to the anisotropic medium (3D).
