Surface Impedance (Ohm)
This option specifies a user defined complex surface impedance Zs.
Figure 1. The DI - Set medium properties dialog, set to Impedance sheet.
For surfaces the unit of Zs is . For wire structures, the value used by Feko is in units of and results from the surface impedance expression by dividing it by where represents the wire radius.
The properties for the surface impedance are as follows:
- Real part
- The real part of the surface impedance Zs in (for triangles) or in for wires.
- Imaginary part
- The imaginary part of the surface impedance Zs in (for triangles) or in for wires.
