KL Card
The KL card defines a wedge for which correction terms are added to the PO currents on two surfaces connected to it.
On the Solve/Run tab, in the Rays group,
        click the
 Physical optics
        icon. From the drop-down list, select the
 PO wedge (KL) icon.
Figure 1. The KL card - Specify a PO region border wedge dialog.
Parameters:
- K1
 - The start point of the axis of the cone (the centre of the base).
 - K2
 - The end point of the axis (the tip of the cone, or the centre point of the circle when creating a conical section).
 - P0
 - A point on the O side of the wedge.
 - PN
 - A point on the N side of the wedge.
 - Label of the O side triangles
 - The label of the PO triangles that are adjacent to the wedge on the O side. This means that the corresponding correction term for the O side is assigned to the PO triangles that have this label.
 - Label of the N side triangles
 - The label of the PO triangles that are adjacent to the wedge on the N side. This means that the corresponding correction term for the N side is assigned to the PO triangles that have this label.
