Reviewing Maximum Penetration Depth
The steps to access the contact overview results for the simulation are:
Select Contact Overview in the Results Browser in the left of the window:
Select the Contour button in the toolbar:
Select the Contour Penetration Depth (s) for the Result
type in the panel:
Select Components in the Selection input
collector:
Select the graphics in the graphics window.
Click Apply.
Inspect the results.
Tip: The overview results are best seen if you change the opacity of the body graphics:
- Select the opacity tool in the toolbar and select Transparent Elements and Feature Lines from the drop-down menu.
