ADVC Conversion
ADVC to OptiStruct Conversion Mapping
Elements
| HM Config | ADVC | OptiStruct |
| tria3 | SHELL | CTRIA3 |
| MEMBRANE | CTRIA3 | |
| quad4 | SHELL | CQUAD4 |
| MEMBRANE | CQUAD4 | |
| tria6 | SHELL | CTRIA6 |
| MEMBRANE | CTRIA6 | |
| quad8 | SHELL | CQUAD8 |
| MEMBRANE | CQUAD8 | |
| tetra4 | 3DTETRA | CTETRA |
| pyramid5 | 3DPYRA | CPYRA |
| penta6 | 3DPENTA | CPENTA |
| 3DGASKET | CGASK6 | |
| 3DUNIAXIALGASKET | CGASK6 | |
| hex8 | 3DHEX | CHEXA |
| 3DIMHEX | CHEXA | |
| 3DRIHEX | CHEXA | |
| 3DGASKET | CGASK8 | |
| 3DUNIAXIALGASKET | CGASK8 | |
| tetra10 | 3DTETRA | CTETRA |
| tetra10 | 3DMTETRA | CTETRA |
| pyramid13 | 3DPYRA | CPYRA |
| penta15 | 3DPENTA | CPENTA |
| hex20 | 3DHEX | CHEXA |
| rigid | Rigid | RBE2 |
| rbe3 | Interpolation Constraint | RBE3 |
Contact
| Type | ADVC | OptiStruct |
| Contact | Small Sliding | Contact Pair, small sliding |
| Finite Sliding | Contact Pair, CONSLI | |
| Tying | TIE | |
| Tying, RIGID | TIE, 123456(DOF) | |
| Search Gap | SRCHDIS | |
| Adjust | Adjust | |
| Clearance | Clearance | |
| Node to Segment | Node to Surface | |
| Surface Behavior | PCONT, Yes | |
| Use Thickness, Yes | PCONT, GPAD, Thick | |
| Use Thickness, No | PCONT, GPAD, None | |
| Segment to Segment | Surface to Surface | |
| Friction | Static Friction | PCONT, MU1 |
| Kinetic Friction | PCONT, MU2 |
Loads
| ADVC | OptiStruct |
| Load(force) | FORCE |
| Pressure | PLOADSF/PLOAD4 |
| Load(moment) | FORCE |
| Forced Displacement | SPC |
| PretensionSectionElement | PTFORCE, PRETENS |
| PrestensionSectionSurfaceList | PTFORCE, PRETENS |
| InitialTemperature | SPC |
Loadsteps
| ADVC | OptiStruct |
| STATIC | Linear/Nonlinear Quasi Static |
| Eigen Value | Normal Modes |
Materials
| ADVC | OptiStruct |
| ISOTROPIC | MAT1 |
| ANISOTROPIC | MAT2(SHELL) |
| ANISOTROPIC | MAT9(SOLID) |
| ORTHOTROPIC | MAT9 |
| ELASTIC-PLASTIC | MAT1/MATS1/MATT1/MATT4 |
| GASKET | MGASK |
Properties
| ADVC | OptiStruct |
| SHELLTHK | PSHELL |
| MEMBRANETHK | PSHELL |
| AUTO_HM_SOLID | PSOLID |
Sets
| ADVC | OptiStruct |
| ELEMENT_SET | SET_ELEM |
| NODE_SET | SET_GRID |
| SURFACE_SEGMENT | SURF |
