Create Multiple Query Surfaces Simultaneously from Order Lines
- From the HyperGraph 3D Data Query panel, click Add n… under the Cut list.
- Enter a list of orders separated by commas or spaces in the Order list= field. Use an underscore, _, to specify a range.
- Enter a p#w#c#.vector vector reference in the Input vector = field or, while holding down the Shift key, left-click on a curve in HyperGraph 3D to automatically insert that curve’s magnitude reference.
                Or, use the curve selector.
                - Click the curve selection button in the Response text box to display the Curves dialog.
- Choose a curve from the Curve tree and click Select.
- You can also click Preview to view the curve in the Preview dialog before selecting it.
- Click Close to close the Curve dialog.
- The Time vector = field is automatically filled in. However, this can be changed. See Step 3 on selecting curves.
- Click OK to create a cut for each specified order.
