Create a New Query Surface at an Order
- From the HyperGraph 3D Data Query panel, click Add under the Cut list to add a new cut.
- Set Type to Order.
- In the Input vector = field, enter a p#w#c#.vector vector reference or, while holding down the Shift key, left-click on a curve in HyperGraph 3D to automatically insert that curve’s magnitude reference.
Or
                Use the curve selector to select a curve.
                - Click the curve selection button in the Input vector text box to display the Curves dialog.
- Choose a curve from the Curve tree and click Select.
- You can also click Preview to view the curve in the Preview dialog before selecting it.
- Click Close to close the Curve dialog.
- In the Time vector = field, enter a p#w#c#.vector vector reference or, while holding down the Shift key, left-click on a curve in HyperGraph 3D to automatically insert that curve’s time reference.
Or
- Or, use the curve selector to select a curve (see step 4).
- Select the order from the Order combo box.
Or
- Click the waterfall plot to specify an order that passes through the selected point.
- Click Apply to create the cut.
