Compare Data
- Result Type
- From the Result Type drop-down list, select the Y-Types available for the reference file specified on page one.
- Result Request
- From the list provided, select single or multiple Y-Requests for comparison.
- Result Component
- From the drop-down list, select a Y-Component. The list is automatically updated upon selecting items from the Y-Requests list box, with respect to the Y-Type selected.
- Threshold Limit
- To compare the reference file data with comparison file data, input a threshold value.
- Comparison Results
- A tree structure is displayed, if any number of y-requests violate the
                        threshold limit values while comparing.
 Figure 3.
- Parts missing in comparison file
- The files displayed are the Y-Requests missing from the comparison file when compared to the Y-Requests in reference file.
- Back
- Click Back to go back to page one.
- Save Defaults
- Click Save Defaults to save the data from pages one
                        and two.Note: To save the Y-requests in the default file, select the items from request list box.
- Load Defaults
- Click Load Defaults to load a *.def file from the file browser window.
- Close
- Click Close to close the tool.
 to select all of the elements listed.
 to select all of the elements listed. to clear all of your current selections.
 to clear all of your current selections. to select the reverse of the currently selected
                        items.
                        items. to dislay the item in the graphics area. This
                        selection affects each item’s local display control. You can also use this
                        on the entire folder. In such cases, this shows all of the items within that
                        folder (all components for example, etc.).
                        folder (all components for example, etc.). to turn off the item in the graphics area. This
                        on the entire folder. In such cases, this hides all of the items within that
                        folder (all components for example, etc.). to works locally within a specific entity type.
                        For example, if Component(s) are isolated, then all display states of other
                        displayable entities (such as Systems) remain untouched. Isolate displays
                        only the selected entities, turning their display state to on, and turning
                        all other entities of the same type off.
                        all other entities of the same type off. to display selected plots in the HyperGraph
                        window. If you do not want to see the plots on the graphics, deselect the
                        button. This button is on by default.
                        button. This button is on by default. to display selected entities from the list box
                        in a HyperView window. If you do not want to see the entities on the
                        graphics, deselect the button. This button is on by default.
                        graphics, deselect the button. This button is on by default. to display selected entities from list box in a
                        HyperMesh window. If you do not want to see the entities on the graphics,
 , to undock the request list box from
                                the GUI.
                                the GUI.
