Create a Model
- Click the Next arrow twice to continue on to the Define models step, or click Define models in the study Explorer.
                Click on the Add Model button ( ).
                The HyperStudy - Add Model dialog is displayed. ).
                Under Select Type, activate the MotionView option and
                    specify a Label and variable name (Varname). Or, accept the default options and
                    click OK.
                The HyperStudy - Add Model dialog is closed and a model is added to the Models table.Note: The type of model that is loaded will determine the Solver options.
                In the Solver input file column, specify a file name for the solver input
                    file.
 Figure 2. Defining a Model in HyperStudy
                To delete a model, select the model from the table and click on the
                        Remove Model button ( ). ).
