Assembly Wizard
                Model type – “Full vehicle with driver”.
                Primary systems for full vehicle with Altair driver model.
                        Powertrain - The powertrain system available in the library are the
                            following:
                        - Manual transmission
- IC Engine Friction Clutch Powertrain.
- Linear Torque Map Powertrain
- Engine that applies torque directly proportional to driver throttle output.
                            following:
                Select a driveline system.
                        Disk brakes: Apply braking torque on the wheel joint proportional to
                            the driver brake output.
 Figure 3.
