| Driver Outputs |
                      F2Steering angle output of the DriverF3Throttle output of the DriverF4Brake output of the DriverF6Gear output of the DriverF7Clutch VF8Unused |
                | Driver Inputs (1) |
                      F2Vehicle CG (x) wrt Gyro F3Vehicle CG (y) wrt GyroF4Yaw angle wrt GyroF6Roll Angle F7Pitch AngleF8Unused |
                | Driver Inputs (2) |
                      F2Longitudinal velocity wrt gyroF3Lateral velocity wrt gyroF4Yaw rate wrt gyroF6Roll rateF7Pitch rateF8Engine Speed (Only in case of manual transmission) |
                | Driver Inputs (3) |
                      F2Longitudinal acceleration (wrt gyro)F3Lateral acceleration (wrt gyro)F4UnusedF6UnusedF7UnusedF8Unused |
                | Driver Requests - General |
                      F2Distance traveledF3UnusedF4UnusedF6UnusedF7UnusedF8Unused |
                | Driver Requests – Long Control (Feedforward traction control) |
                      F2Demand Signal (Acceleration/Velocity)F3Control Signal (Acceleration/Velocity)F4Error (Demand – Control Signal)F6UnusedF7UnusedF8Unused |
                | Driver Requests - Steer Controller (Feedforward steer control) |
                      F2Path x coordinateF3Path y coordinateF4Distance along centerlineF6- Laps completed (Cars/Trucks)- Demand path curvature (Two wheelers)F7Path ErrorF8Distance travelled |
                | Driver Requests – Long Control Feedback (PID traction control) |
                      F2Demand Signal (Acceleration/Velocity)F3Control Signal (Acceleration/Velocity)F4Error (Demand – Control Signal)F6Error derivativeF7Error integralF8Unused |
                | Driver Requests - Steer Control Feedback (Two wheelers Steer
                  control) |
                      F2Demand lean angleF3Vehicle lean angleF4ErrorF6Error derivativeF7Error integralF8Steer output |
