Add Objectives and Constraints
                From the Optimization Setup section of the Optimization Wizard, click the
                        Add button in its respective section.
                Choose the response from the list of available responses.
                Restriction: Only one objective and/or constraint can be added per response. Thus, the maximum number of total objectives or constraints cannot exceed the total number of active responses in the study.
