Accessing the Context Menu
                From the FLD panel, right-click anywhere within the FLD Studies list.
                The context menu is displayed.
                Click on one of the available options.
                Delete Deletes the selected study (or studies) from the list. Rename Displays the Rename dialog, which allows you to rename the selected study. Make Current Allows you to select which study will be activated and displayed in the modeling window. This option performs the same action as clicking the radio button "on" next to a study.
