Masking Simulation Data
- Load a simulation using the Load Model panel.
- Display the blank components for which a Forming Limit Diagram (FLD) is to be plotted.
                Define or load a forming limit curve (FLC).
                An FLC is displayed in a separate 2D window for you to preview.Tip: For comparison purposes, you can create additional FLD studies on the same model using various FLC definitions.
                Return to the FLD panel and create an FLD using a reference FLC.
                The following items are displayed: the FLC, the safety curve, ±45 degree lines, and the elemental major and minor strains for the selected components in an xy-plot.
- Optional:
                Click the Query elements icon  to
                    select individual elements on the model, which are then highlighted on the
                    forming limit diagram. to
- Optional:
                Click the Query FLD plot icon  to open the Coordinate Info panel where you can select curve points that will
                    then be highlighted on the formability contour. to open the Coordinate Info panel where you can select curve points that will
- Optional:
                Click the Trace strain path of element
                     to select element(s) on the model and trace their
                    deformation path in the Forming Limit Diagram. to select element(s) on the model and trace their
