Apply a Contour to a Streamline
- From the Streamlines panel, follow the steps to create a Line, Area, or Plane rake/streamline.
                From the Plot tools, click the Contour tool.
                 Figure 1. Figure 1.
- Select a result type from the Result type drop-down menu.
                Click Apply.
                The contour is applied to the streamline.Restriction: HyperView supports streamline contouring for nodal results only (elemental results are currently not supported).
