Access Upfront Data Loader
  • To access the Upfront Data Loader on Windows, select Altair 2022.2 > HyperWorks from the Start menu.
    • From the Startup dialog, select HyperView and use the Profile drop-down menu to select the Upfront Loader profile.
    • Click Create Session.
  • To access the Upfront Data Loader on Linux, run hvxul from the <install_dir>/altair/scripts directory.
This will set the proper environment to run the Upfront Data Loading infrastructure on HyperWorks.
