MPDB Tool
The MPDB tool offers a complete automated post processing solution of the MPDB Frontal Compatibility Assessment load case, for Radioss and LS-DYNA output files.
Figure 1. Figure from Carhs Safety Companion 2019
        Figure 2.  .
.  Figure 3.
        Figure 3. Select MPDB to display the MPDB Projection Tool dialog.
Figure 4.
- The definition of the rating area of the PDB front face
- The calculation of the standard deviation of the post-test barrier deformation
- The calculation of a bottoming out scenario
- The calculation of the Occupant Load Criterion (OLC)
- The calculation of the Compatibility Modifier
- Automatic Results report generation
