Material Orientation
The Material Orientation tool provides several methods of assigning material x directions for shell and solid elements, and additionally z directions for solid elements.
  1. Select the Entities on which to assign material orientation, either Elements or Properties.
  2. Set the Color of orientation vectors drawn after applying material orientation.
  3. To set the scale of orientation vectors drawn after applying material orientation, set Scaling Option to Auto or Manual.
  4. Type a value into the Size field for the manual input for size of orientation vectors drawn after applying material orientation.
  5. Set the X direction method. Choose from the following:
    • Curve – spatially map input curve(s) as the x direction
      • Lines/Edges – lines which define the orientation
      • Flip direction – for lines/edges only. Determines whether the curve provided is +x direction or -x direction.
      • Nodes – list of lines that define the orientation
    • System ID – system assigned as orientation
    • System Axis – system and axis of system to map as x direction
    • Angle – for OptiStruct and Nastran only. Directly enter rotation applied on THETA field of element.
  6. Set a value for Normal by choosing one of the following:
    • Element Normal – uses element z direction (can be viewed from 2D > composites > element normals panel if elements are selected). Typically, this option should be used.
    • Surface Normal – aligns material z direction spatially to selected surface.
By Curve
Using curves/lines to create material direction:
  1. Select the elements for which a new material angle will be assigned.
  2. Select the lines or list of nodes to define the material direction. The element centroid will be taken and projected to the closest line/node segments and the line tangent direction will be found to assign the material angle.
    Figure 1. A Circular Pattern of the Material Orientation is Assigned Based on the Outer Circular Line Direction
Other material orientation tools are also available.
By Node: Element material direction can be assigned using two nodes.
Figure 2. Two Nodes are Selected for Material Direction
Figure 3. Material Direction in the Same Direction as two Nodes
By System ID
The X axis of the selected system is projected to the elements to create element material direction.
Figure 4. X Axis of the System is used for Projection
By System Axis
You can select a local system and the direction of the axis to be projected to elements and create material direction.
Figure 5. System Local Axis 2 is Projected to Create Material System
By Angle
You can provide an angle by which material direction is rotated from the element N1-N2 direction.
Figure 6. Element N1-N2 Direction
Figure 7. Material System is Created at an Angle to N1/N2 Direction
