HyperView Moldflow Results Reader
HyperView supports the Patran neutral format for post-processing Moldflow results.
Moldflow can export Patran format files using a Visual Basic script. To export the results into the Patran format, run the patout.vbs script using the Play macro tool option from the Tools menu in Moldflow. Refer to the Moldflow documentation for complete information on obtaining and using the patout.vbs script.
After you have run the patout.vbs script, you will have several ASCII result files that are prefixed with pat_ and have the file extension .ntr.
Supported Results
| Data Name | Results Type | Data Type |
| Velocity (3D) | NODE | VECTOR |
| Fill Time | NODE | SCALAR |
| Grow from | NODE | SCALAR |
| Pressure | NODE | SCALAR |
| Pressure (end of filling) | NODE | SCALAR |
| Pressure at V/P switchover | NODE | SCALAR |
| Temperature at flow front | NODE | SCALAR |
| Extension rate (3D) (s) | NODE | SCALAR |
| Shear rate (3D) (s) | NODE | SCALAR |
| Shear rate, maximum | NODE | SCALAR |
| Temperature (3D) (s | NODE | SCALAR |
| Viscosity | NODE | SCALAR |
| Average velocity | ELEMENT | VECTOR |
| Orientation at core | ELEMENT | VECTOR |
| Orientation at skin | ELEMENT | VECTOR |
| Bulk temperature | ELEMENT | SCALAR |
| Bulk temperature (end of filling) | ELEMENT | SCALAR |
| Flow rate, beams | ELEMENT | SCALAR |
| Frozen layer fraction | ELEMENT | SCALAR |
| Shear rate, bulk | ELEMENT | SCALAR |
| Shear stress at wall | ELEMENT | SCALAR |
| Throughput | ELEMENT | SCALAR |
Loading the Results in HyperView
Load the .UDM model files in HyperView following the standard procedure for loading model and results with one file with the Load Model panel. Click Apply; HyperView will create a model content table and results table for post-processing.
