Align 1D Elements
Use the Edit Beam: Align tool to reorder the N1 to N2 sequence of 1D element nodes.
This tool allows you to reorder element nodes using a vector or a system axis.
In this optional step, you can select elements in order to reorder N1 & N2 in ascending order along one or multiple axes if elements are aligned with such vector(s) in a given angle tolerance.
 to invoke the
 to invoke the
. - Save changes and stay in the tool
 - Save changes and stay in the tool - Save changes and close the tool
