Load Representations from the Part Library
After importing a BOM that has representations saved in the Part library, you can load the saved representations.
  1. In the Part Browser, right-click on a part/part assembly and select Representations > Load > from Library from the context menu.
  2. In the Change Representation dialog, Library tab, select representations and click OK.
The selected representations are loaded to the Representation folder on the file system. Similarly, every time a BOM is imported, files are loaded to the Representations folder, if you retrieve them from the Part Library.
