Find Equivalent Joints
Use the Equivalence tool to consolidate overlapping joints within a given tolerance.
|  Figure 2. . Original model containing overlapping joints |  Figure 3. . Post equivalence the overlapping joints are consolidated |
|  Figure 4. . Original model containing three joints located in the center of the members. If “Allow member destruction” is active, the central members are removed. |  Figure 5. . Post equivalence the joints are consolidated, and the two members are removed |
 on the
 on the  or
 or  to
                    review each instance.
 to
