Create Joint Hubs
Use the Joint Box tool to define junctions in your skeleton model.
Figure 1. Original model
                From the Skeleton ribbon, click the Joint Box
                    tool.
                Select the node or elements around which to create a bounding box.
                Any elements found within the box are used for joint creation.
 Figure 3.
                Click  on the guide bar to define
                    options. on the guide bar to define
                    options.- Create joint box
- Use the box as a mechanism to select elements to generate the joint location and legs.
- Remove joint legs
- Create a joint without the corresponding legs.
- Mesh member joint
- Automatically create 1D mesh on the joint legs and apply the beam sections.
- Dimensions
                                Controls the length, width, and weight of the bounding box.
- Use orientation and dimensions
- For repeated operations, the previous box attribute information can be used so that the box can be created the same repeatedly.
                Edit the box size in the following ways:
                - Click  in the microdialog to
                        move the box globally. in the microdialog to
                        update the box's dimensions. You can click a face and drag its arrow or
                        entire a precise value. in the microdialog to
 Figure 4.
- Click
                If the member joint is being meshed, set the parameters in the microdialog drop-down.
                This automatically creates 1D mesh on the joint legs and applies the beamsections.
 Figure 5.
- Optional: Click the Exclude selector on the guide bar then pick entities to exclude from the joint if required.
                On the guide bar, click one of the following:
                 - Apply and stay in the tool - Apply and stay in the tool
 - Apply and close the tool - Apply and close the tool
 - Exit the tool without applying - Exit the tool without applying
Assign Beam Sections to Member Joints
Use the Assign tool if a member joint is created without a beam section or the beam section needs to be changed.
                From the Skeleton ribbon, Joint Box tool group, click the
                        Assign tool.
 Figure 6.
- Select the member joint(s).
- Select the beam section to assign.
