Create Members
Use the Members tool to create members between two joints.
                From the Skeleton ribbon, click the Members tool.
- Select a starting joint.
                Select an ending joint or a symmetry plane.
                Sections are created in between the two.
 Figure 2. . The primary joint is selected and then the symmetry plane. The preview shows the sections in symmetry, these can be edited as required .
                Click  on the guide bar to define
                    options. on the guide bar to define
                    options.- Number of control points
- The number of sections that are created throughout the symmetric member creation.
- Cut planes
- The default length and width of the cut plane.
- Realize member
- Create 1D mesh and the associated beam sections based on the cut plane sections.
                Resize and reposition the planes in the following ways:
                - Click and drag the boxes at the edges of the plane(s) to resize and capture the appropriate structure.
- Toggle  in the microdialog to
                        move each plane globally. Use the drop-down menu to control which section(s)
                        display the manipulator. in the microdialog to
- Click  in the microdialog to
                        align the last member created. Press Ctrl + Z to
                        undo. in the microdialog to
                        undo.
- If the member is being realized , define the 1D mesh and the associated beam sections.
- Optional:
                Click the Exclude selector on the guide bar then pick entities to exclude from the member if
                    required.
 Figure 3. . The member, 1D mesh, and beam sections are created and applied appropriately
                On the guide bar, click one of the following:
                 - Apply and stay in the tool - Apply and stay in the tool
 - Apply and close the tool - Apply and close the tool
 - Exit the tool without applying - Exit the tool without applying
Assign Beam Sections to Members or Member Sections
Use the Assign tool if a member is created without a beam section or the beam section needs to be changed.
                From the Skeleton ribbon, Member tool group, click the
                        Assign tool.
 Figure 4.
- Select the members or member sections.
- Select the beam section to assign.
