Change Part of a Curve's Math Expression
- To display the Parameters Browser, click View > Parameter Browser in any client beside HyperMesh.
                Right-click within the white space of the browser and
                    select Expand All.
                The browser is expanded to show the entire contents of the session.
                Under Y vector for a math curve, activate the check box next to
                    Expression.
                A new row is added to the parameter table in the lower half of the Parameters Browser.
                Click the ellipse button,  , next
                    to the default math expression to display the More Options
                    dialog. , next
                    dialog.
- In the Name field in the parameter table, enter a description for the parameter.
- Change Value type to Range.
                Set the Default value.
                - In the Expression text box, highlight the default value. You can highlight multiple occurrences of the default value.
- Click OK.
                Click Save,  , to save
                    the script template. , to save
- Click File > Session > Flexible Reports to display the Flexible Report Templates dialog.
- In the Expression field, change the default value.
                Click Apply.
                The session is recreated using the new value in the math expression.
 , to display the
, to display the
