Context Menu
Right-click on any parameter in the parameter table, or in the white space within the browser, to display additional options.
- Collapse All
- If you select Collapse All in the white space of the browser, this option collapses all items in the browser tree. If you have a particular entity or folder selected in the browser and select Collapse All, then this option only collapses the items beneath the currently selected entity or folder.
- Expand All
- If you select Expand All in the white space of the browser, this option expands all items in the browser tree. If you have a particular entity or folder selected in the browser and select Expand All, then this option only expands the items beneath the currently selected entity or folder.
- Select All
- For the entity type currently selected, this option selects all items of that type in the browser.
- Select All in Page
- For the entity type currently selected, this option selects all items of that type in the current page.
- Select All in Window
- For the entity type currently selected, this option selects all items of that type in the current window.
- Show/Hide Filter
- Displays or hides the filter options at the top of the browser.
The following context menu options are displayed when you
                right-click on an automation script parameter at the bottom of the browser.
        - Remove Parameter
- Deletes the parameter.
- Merge
- If two or more parameters are selected, this option merges them into one automation script parameter.
- Show in Tree
- Highlights and displays the location of the selected parameter in the
                                browser tree.Note: If a parameter has been selected for multiple attributes, the Show in Tree option automatically highlights and displays the location of the selected parameter for each selected attribute.
 , to display the
, to display the
