Filter Attributes
- Show
- Allows you to select specific client type(s) to display. Check those you want to display in the browser; uncheck to hide. Click OK to close the window.
- Matching
- You can also select groups of entities based on a wildcard search. For
example, if you type *collector and press
Enter, all entity types ending with
"collector" will be checked and display in the list. You can fine-tune
the search by selecting one of the following options from the icon:
- Match case
- Only selects items that match the entered text exactly, including upper/lower case letters.
- Whole name
- Only selects items whose entire name matches the specified text. For example, typing pillar in the Matching: field when using the Whole name option will not locate a component named "CH-A-PILLAR-B-I-L". To find such a component, you would need to run a wildcard search for something such as *pillar*.
- Entity
- Distinguishes which types of entities to display. Select an option from the drop down menu to display only that entity type. Select All to display all entities.
- Filter,
- Activates a field for entering text to display only those items that contain that text. For example, entering "*color" displays all attributes that specify colors.
- Save
- Saves the current session, with the parameters selected, as a report template automation script (*.tpl file). This script can be run at any time from the Flexible Report Templates dialog.
