PARAM, AUNITS
Bulk Data Entry Converts accelerations specified in units of gravity on the TRIM Bulk Data Entry to units of distance per time squared.
Parameter Values Description
AUNITS <REAL>
Default = 1.0
Accelerations are divided by this parameter.
To convert accelerations input in g’s into physical, consistent units, set PARAM,AUNITS to 1/g.
