PARAM, PRGPST
Bulk Data Entry Outputs AUTOSPC information to the .out file.
Parameter Values Description
PRGPST < YES, NO, ALL, NONE, <number of DOFs> > PRGPST controls the printing of AUTOSPC information to the .out file.
YES (Default)
A maximum of 100 degrees-of-freedom (DOF) of AUTOSPC data will be printed in the .out file.
NO and NONE
No AUTOSPC data will be printed.
ALL
All AUTOSPC data will be printed in the .out file.
<number of DOF>
A maximum of <number of DOF> degrees-of-freedom (DOF) of AUTOSPC data will be printed in the .out file.
  1. If the total number of AUTOSPC dofs is less than 100, all the AUTOSPC dofs will be printed, regardless of the number of dofs specified. When the total number of AUTOSPC dofs is more than 100 and the printing is limited by default value of 100, you can specify the number of dofs to print more than 100 in .out file.
