PARAM, RBE3COL
Bulk Data Entry This parameter controls the handling of RBE3 elements.
| Parameter | Values | Description |
| RBE3COL | <ERROR, LINETRANS, LINEROTA, OFFSET> | Controls the handling of
RBE3 elements which satisfy the following conditions:
- For PARAM,RBE3COL,LINETRANS, the run will error out if condition 3 is not satisfied for any RBE3.
- For PARAM,RBE3COL,LINEROTA, the run will error out if condition 3 is not satisfied for any RBE3.
- For PARAM,RBE3COL,OFFSET the run will not error out if condition 3 is not satisfied for any RBE3. Therefore, it is important to be cautious when using PARAM,RBE3COL,OFFSET since it may lead to unexpected behavior when the dependent grid is away from the axis of collinearity of the independent grids.
