Delete a Derived Load Case
Do one of the following:
- From the Results toolbar, click Derived Load
Steps
. - Select Create > Derived Load Steps from the Results menu.
- Right-click in the Results Browser and select Create > Derived Load Case then a load case type.
The Create/Edit Derived Load Case dialog is displayed. - From the Results toolbar, click Derived Load
Steps
- Select a load case from the Derived load case drop-down menu in order to make it active.
Click Delete.
The last derived load case that remains in the list becomes the active derived load case.
