Rename a Derived Load Case
Do one of the following:
- From the Results toolbar, click Derived Load
Steps
. - Select Create > Derived Load Steps from the Results menu.
- Right-click in the Results Browser and select Create > Derived Load Case then a load case type.
The Create/Edit Derived Load Case dialog is displayed. - From the Results toolbar, click Derived Load
Steps
- From the Derived load case drop-down menu, select a load case to make it active.
Click Rename.
The Rename dialog is displayed.
- Type a new label in the text field and press Enter.
