Remove Load Cases or Simulations from a Derived Load Case
Do one of the following:
- From the Results toolbar, click Derived Load
Steps
. - Select Create > Derived Load Steps from the Results menu.
- Right-click in the Results Browser and select Create > Derived Load Case then a load case type.
The Create/Edit Derived Load Case dialog is displayed. - From the Results toolbar, click Derived Load
Steps
- Select one or more simulation time steps from the derived load case list.
Click the left blue arrow
(remove button).
The simulation time steps are removed from the list.
