hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Allows an element to be moved from one collector to another.
Moves the entity identified by ID to the new location.
ON THIS PAGE
ON THIS PAGE
