HMIN_move_write()
Allows an element to be moved from one collector to another.
void HMIN_move_write(char * name);
HyperMesh hminlib Function
name
The name of the collector where the element should be placed.
HMIN_move_writeid() must be called next to identify the entity that should be moved. No other hminlib functions may be called until all moves for the given collector are complete.
None.
