HyperWorks Desktop
HyperWorks Desktop
2022
  1. Home
  2. HyperWorks Reference Guides
  3. HyperMesh
  4. FE Input Readers
  5. Commands and Functions
  6. hminlib Functions
  7. Transfer Functions
  • What's New
  • Get Started
  • Tutorials
  • Manage Files and Data
  • Display Controls
  • Session Navigation
  • Publish Sessions
  • Parameterize Report Templates
  • Workflow Automation
  • HyperWorks Collaboration Tools
  • HyperWorks Reference Guides
Index
HyperWorks Desktop
2022
HyperWorks Desktop
  • What's New
  • Get Started
  • Tutorials
  • Display Controls
  • Publish Sessions
    • Extensions
    • External Readers and Altair Binary Format
    • Generic ASCII Reader
    • Batch Mode
    • External Resources
    • Tcl/Tk Commands
    • Translators
    • Result Math
    • HyperWorks Record and Playback
    • HyperWorks Report
    • HyperMesh
      • API Programmer's Guides
      • Data Names
      • Ext API
      • FE Input Readers
        • Result Readers
        • hmlib
          hmlib is a library which contains a set of routines to aid you in writing a C program.
        • hminlib
          hminlib is a set of routines which allows you to write an external input translator.
        • hmmodlib
          hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
        • hmreslib
        • Create FE Input Readers
        • Commands and Functions
          • hmlib Functions
          • hminlib Functions
            • Basic Functions
            • File Locator Functions
            • ID Functions
            • Message Functions
            • Move Functions
            • Rename Functions
            • Transfer Functions
              • assemblies
              • attributes
              • bags
              • blocks
              • cards
              • components
              • connectors
              • contactsurfs
              • controlvols
              • curves
              • dequations
              • designvars
              • desvarlinks
              • dictionaries
              • dvprels
              • elements
              • ellipsoids
              • equations
              • groups
              • laminates
              • lines
              • loadcols
              • loads
              • loadsteps
              • materials
              • mbjoints
              • mbplanes
              • metadata
              • miscellaneous
              • multibodies
              • nodes
              • objectives
              • opticonstraints
              • opticontrols
              • optidscreens
              • optiresponses
              • outputblocks
              • plies
              • plots
              • properties
              • sensors
              • sets
              • surfaces
              • systemcols
              • systems
              • tables
              • tags
              • titles
              • vectorcols
              • vectors
              • Deprecated hminlib Functions
                The list of deprecated hminlib functions, and the new functions to use.
              • Undocumented hminlib Functions
                The list of undocumented hminlib functions.
          • hmmodlib Functions
          • hmreslib Functions
      • HMASCII
      • Scripts
      • Solver Templates
    • MotionView
    • Templex and Math Reference Guide
    • Script and Model Library
View All Altair Simulation Help
HyperWorks Desktop
HyperWorks Desktop
2022
  1. Home
  3. HyperMesh
  4. FE Input Readers
  • What's New
  • Get Started
  • Tutorials
  • Display Controls
  • Publish Sessions
Index
Transfer Functions
  • assemblies
  • attributes
  • bags
  • blocks
  • cards
  • components
  • connectors
  • contactsurfs
  • controlvols
  • curves
  • dequations
  • designvars
  • desvarlinks
  • dictionaries
  • dvprels
  • elements
  • ellipsoids
  • equations
  • groups
  • laminates
  • lines
  • loadcols
  • loads
  • loadsteps
  • materials
  • mbjoints
  • mbplanes
  • metadata
  • miscellaneous
  • multibodies
  • nodes
  • objectives
  • opticonstraints
  • opticontrols
  • optidscreens
  • optiresponses
  • outputblocks
  • plies
  • plots
  • properties
  • sensors
  • sets
  • surfaces
  • symmetries
  • systemcols
  • systems
  • tables
  • tags
  • titles
  • vectorcols
  • vectors
