materials
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Writes a material to HyperMesh.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
