laminates
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Writes a laminate entity to the database.
Assigns a ply or sub laminate to a laminate.
Assigns interface ply pair information to a laminate.
Assigns entities that reference a laminate.
Assigns a system ID to a laminate.
Assigns a table ID to a laminate.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
