HMIN_rigidwall_writenode()
Writes a basic rigid wall to HyperMesh.
HMIN_rigidwall_writenode(HM_entityidtype id, HM_entityidtype nodeid, normalx,double normaly, double normalz);
HyperMesh hminlib Function
id
The ID of the rigid wall.
nodeid
The ID of the base node.
normalx, normaly, normalz
(x, y, z) locations used to calculate the vector for the rigid wall.
This command must be preceded by a HMIN_group_write() command with the same ID.
None.
