elements
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Determines the number of nodes associated with the configuration of the element.
Writes a 2-noded bar with property idpool to HyperMesh using a vector to define the bar local x axis.
Writes a 2-noded bar element with property idpool to HyperMesh using a node to define the local bar y axis.
Writes a bar element with property idpool to HyperMesh using a node to define the local bar z axis.
Writes a 3-noded bar with property idpool to HyperMesh using a vector to define the bar local x axis.
Writes a 3-noded bar element with property idpool to HyperMesh using a node to define the local bar y axis.
Writes a gap element with property idpool to HyperMesh.
Writes a joint element with property idpool to HyperMesh.
Writes a mass element with property idpool to the HyperMesh database.
Writes a rod element with property idpool to HyperMesh.
Writes a 2-noded bar to HyperMesh using a vector to define the bar local x axis.
Writes a 2-noded bar element to HyperMesh using a node to define the local bar y axis.
Writes a bar element to HyperMesh using a node to define the local bar z axis.
Writes a 3-noded bar to HyperMesh using a vector to define the bar local x axis.
Writes a 3-noded bar element to HyperMesh using a node to define the local bar y axis.
Writes a gap element to HyperMesh.
Creates a main or secondary element from an existing element in HyperMesh.
Writes an eight-noded brick solid element to HyperMesh.
Writes a twenty-noded brick solid element to HyperMesh.
Writes a joint element to HyperMesh.
Writes a three-noded main interface element to HyperMesh.
Writes a four-noded main interface element to HyperMesh.
Writes a mass element to the HyperMesh database.
Writes a five-noded solid pyramid element to HyperMesh.
Writes a six-noded wedge solid element to HyperMesh.
Writes a thirteen-noded, second order solid pyramid element to HyperMesh.
Writes a fifteen-noded wedge solid element to HyperMesh.
Writes a plot element to HyperMesh.
Writes a four-noded quadrilateral shell element to HyperMesh.
Writes an eight-noded quadrilateral shell element to HyperMesh.
Writes an RBE3 element to HyperMesh.
Writes an RBE3 element header to HyperMesh.
Writes the nodes that define the RBE3 element to HyperMesh.
Writes a rigid element to HyperMesh.
Writes a rigid link element to HyperMesh.
Writes a rigid link header to HyperMesh.
Writes the nodes that define the rigid link to HyperMesh.
Writes a rod element to HyperMesh.
Creates a secondary element from an existing element in HyperMesh.
Writes a one-noded secondary interface element to HyperMesh.
Writes a three-noded secondary interface element to HyperMesh.
Writes a four-noded secondary interface element to HyperMesh.
Writes a spring element to HyperMesh.
Writes a four-noded tetrahedral solid element to HyperMesh.
Writes a ten-noded tetrahedral solid element to HyperMesh.
Writes a three-noded triangular shell element to HyperMesh.
Writes a six-noded triangular shell element to HyperMesh.
Writes a weld element to HyperMesh.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
