HMIN_element_solver_writerod()
Writes a rod element with property idpool to HyperMesh.
void HMIN_element_solver_writerod(HM_entityidtype id, char elementtype, HM_entityidtype propertyid, HM_entityidtype nodes[], HM_entityidtype collectorid, int propsidpool)
HyperMesh hminlib Function
id
ID of the element.
elementtype
The type of the element, a user-defined value.
propertyid
The ID of the property to which the rod element should point.
nodes[1]
The nodes associated with the element.
collectorid
The ID of the collector where the rod element should be placed.
propsidepool
ID pool number of the property to which the element should point.
None.
