HMIN_element_writegap()
Writes a gap element to HyperMesh.
void HMIN_element_writegap(HM_entityidtype id, char elementtype, HM_entityidtype propertyid, HM_entityidtype nodes[], int collectorid, HM_entityidtype vectorid);
HyperMesh hminlib Function
id
The ID of the element.
elementtype
The type of the element, a user-defined value.
propertyid
The ID of the property to which the gap element should point.
nodes[2]
The nodes associated with the element.
collectorid
The ID of the collector where the gap element should be placed.
vectorid
The ID of the vector associated with the element.
None.
