HMIN_element_writerbe3header()
Writes an RBE3 element header to HyperMesh.
void HMIN_element_writerbe3header(HM_entityidtype id, char elementtype, HM_entityidtype collectorid);
HyperMesh hminlib Function
id
The ID of the element.
elementtype
The type of the element, a user-defined value.
collectorid
The collector where the rbe3 element should be placed.
HMIN_element_writerbe3node() should be called immediately after HMIN_element_writerbe3header() to add nodes to the element.
None.
