HMIN_element_writerod()
Writes a rod element to HyperMesh.
void HMIN_element_writerod(HM_entityidtype id, char elementtype, HM_entityidtype propertyid, HM_entityidtype nodes[], HM_entityidtype collectorid);
HyperMesh hminlib Function
id
The ID of the element.
elementtype
The type of the element, a user-defined value.
propertyid
The ID of the property to which the rod element should point.
nodes[2]
The nodes associated with the element.
collectorid
The ID of the collector where the rod element should be placed.
None.
