HMIN_element_solver_writespring()
Writes a rod element with property idpool to HyperMesh.
void HMIN_element_solver_writespring(HM_entityidtype id, char elementtype, HM_entityidtype propertyid, int dof, HM_entityidtype nodes[], HM_entityidtype collectorid, HM_entityidtype vectorid, int propsidpool)
HyperMesh hminlib Function
id
ID of the element.
elementtype
The type of the element, a user-defined value.
propertyid
The ID of the property to which the spring element should point.
dof
The degree of freedom associated with the element.
nodes[1]
The nodes associated with the element.
collectorid
The ID of the collector where the spring element should be placed.
vectorid
The ID of the vector associated with the element.
propsidepool
ID pool number of the property to which the element should point.
None.
