HMIN_element_writerbe3node()
Writes the nodes that define the RBE3 element to HyperMesh.
void HMIN_element_writerbe3node(HM_entityidtype nodeid, double coefficient, int dofs, int dependent_flag);
HyperMesh hminlib Function
nodeid
The ID of the node to add to the RBE3 element.
coefficient
The coefficient to be associated with the node (may be set to 0).
dofs
The degrees of freedom to be associated with the node (may be set to 0).
dependent_flag
Set to 0 to define the independent node, and 1 to define the dependent nodes.
HMIN_element_writerbe3header() must be called immediately before HMIN_element_writerbe3node(). Only one node may be defined as the dependent node. No other hminlib commands may be used until all RBE3 data is processed for the given element.
None.
