HMIN_element_writerigidlinknode()
Writes the nodes that define the rigid link to HyperMesh.
void HMIN_element_writerigidlinknode(HM_entityidtype nodeid, int dependent_flag);
HyperMesh hminlib Function
nodeid
The ID of the node to add to the rigid link element.
dependent_flag
Set to 0 to define an independent node and 1 to define a dependent node.
The function HMIN_element_writerigidlinkheader() must be called immediately before any nodes can be defined with HMIN_element_writerigidlinknode(). Only one node may be defined as the independent node. No other hminlib comments may be used until all rigid link nodes are processed for the given element.
None.
